Central Kansas | Just went through a similar situation with my 1264. My left side display continued to work fine but the right side would go dark and the raven would shutdown. It would be like the ignition switch just came on and everything would come alive, shifting the transmission back to first and nearly throwing you through the windshield. After a lot of looking, switched the eip relay (think it was k43) with one marked as a spare and the problem seems to be fixed. Good luck! | |
