sw wi | I made L brackets from flat steel that I u-bolt to the boom that extend behind the boom and down when folded out and extend back over tire when folded in. I use a threaded cap with an elbow that attaches to the nozzle body, slide hose on it that goes back to a hose barb elbow that turns the hose down at the bend in the L bracket, then drop hose from there to ground, zip tie or hose clamp the elbows and hose assembly to L brackets. Never have to get out when folding or un-folding booms, works good here on a 854 rogator. | |
