| Not a direct answer to your question, but be sure to get one that is at least a foot wider than your machine. I made the mistake of buying one that is just a little wider as my ATV and it makes plowing in deeper snow difficult with the blade fully tilted.
Mine is a Warn brand and it has held up and is fairly easy to install and remove, but after 8 years of use it's time to rebuild some pivot joints and reinforce high load areas. | |
