Posted 12/9/2013 03:38 (#3503269 - in reply to #3503152) Subject: Re: Can I "trick" Air filter restriction indicator on STX 430
NW Central Ohio
...Is the wiring anywhere that could cause it to heat up? Get the harness too warm, and you'll have more resistance in the wire...seems like you say it doesn't start happening until you've spent an hour or 2 in the field.
