Posted 12/6/2013 13:19 (#3496210 - in reply to #3494411) Subject: Re: Metal rack pictures or ideas?
w/c Illinois
sf 1066's picture above shows a chemical tote in the background. Removing the plastic tank would leave a set of square holes that you could slide 4' and longer pieces into, and you could move it with a fork lift if you wanted to. You could run longer pieces left-to-right and 4' pieces into the front if you staggered the rows.
