Posted 12/5/2013 22:46 (#3494864 - in reply to #3494283) Subject: Re: 99 Yukon vortec won't start
Pilot Grove, Missouri
I don't believe the crank sensor code will reset until it is running. Could be wrong, though. You said fuel was not an issue, but the vortec engines have to have 60-62 psi while cranking to start. If pressure is just a few psi low the poppet valves in the injectors will not open. Patrick
