EC IA | Have an EZ Steer in my fall tillage tractor, worked fine one day next day motor wouldn't turn. Monitor worked fine did the self tests, everything fine but motor all it would do is just twitch a little. Has 2 power cords w/ cigarette lighter ends for power. Switched them back & forth to different power source, everything fine, no gain. Talked to AG Leader Tech support, they thought either needed to be reprogrammed or check power source. So I cut off both cigarette lighter ends wired direct to 3 prong power source (same as what I was plugged into w/ 2 to 1 converter), works perfect???? I've owned this for 5 to 6 years never a problem with these ends. | |
