| Mine is used. Made by ALM. I actually found it when calling the nearest Rotary dealer for a quote on a new one. Mine is 9000 lb and I gave $1800 for it. It is ALI certified, which makes me a little less nervous when I'm standing under my K2500 Suburban. Being fairly old (96 I think) it is made out of MUCH heavier steel than the new ones. Overhead cables are nice if you have the ceiling height so you aren't tripping over the cable passage.
The dealer threw in some extensions that sit on top of the pads for trucks; I have the screw adjust pads also. Mine is symmetrical, which is what I was going to get anyway, and is extra wide & extra tall, but it is still a tight squeeze to get out of the driver's door. | |
