Columbia Basin, Ephrata, WA | This may be kind of outside the box thinking, but could you move everything to 30" spacing with five rows? How well that could work probably depends on the planter and if you can buy one more strip till row unit to match the other four. The frames of all the various things would stay the same, just slide row units on everything and add one. The 1460 will fit behind the header the same as it always has. As a bonus you'll be able to run your tractor tires spaced out wide which will ride better and be more stable.
