Search Forums | Classifieds (128) | Skins | Language
Trimble EZ Guide and EZ Steer
KDD
Posted 7/15/2006 23:28 (#26955 - in reply to #26930)
Subject: Re: Trimble EZ Guide and EZ Steer
Leesburg, Ohio
not sure what you mean by "push RTK...into an EZsteer," dirtpan, but I think the answer is "Yes, you can."
I do know you can hook up an upgraded receiver, such as an Agleader 5100 or Trimble 252 (I think I have the correct numbers) and use the EZsteer with HP signals for about 2-4" accuracy, or RTK for about 1" accuracy. You still need the EZguide Plus lightbar to run the whole deal, though. With another (more accurate) receiver hooked up, I don't think the internal EZguide receiver would be doing anything. The EZsteer would utilize the more accurate info from the "better" receiver, but would get it thru the EZguide. If I have misinterpreted anything, I'm sure there are some others watching that can help us out here. Hope this helps a little.
Ken
Edited by KDD 7/15/2006 23:34
