Posted 12/5/2013 20:11 (#3494321 - in reply to #3493406) Subject: Re: JD 930 hook up
Tx
Instead of cutting the shafts shorter, leave the feederhouse down about 8" before you hook up to the header. Slide the shafts on the adapters, then hook up the header. When unhooking, lower the feederhouse some, then slide the pto shafts off the adapters.
