Posted 12/5/2013 11:50 (#3493183 - in reply to #3492777) Subject: RE: corn dryer problem
north east IN
Replace the ground wire going to the points had the same problem with a kansun drier so ran all the gas out then held the fan switch so it thought it was running then tried to light and could see the ground wire sparking to the frame.
Let use know what you find out......Dave
