| Thanks ccjersey and buster50 , the schematics are great and buster I am interested in your starter. I unhooked the starter and removed it from the tractor and used the tractors batteries and the solenoid and the starter work fine. When I put the starter back on the tractor it turns over but not enough to start the tractor I have 26 volts on top terminal of starter but around 18 volts while cranking on the bottom terminal. Any more ideals would be really helpful.Thanks | |
