ND | When I turm on the PTO, I get a PTO fault 10033, which is low voltage. The PTO fault keeps flashing and says to turn PTO off, I turn the PTO off and it continues to flash until I turn off the tractor. Had someone watch the PTO while I turn it on and it tries to take off then the Fault comes up. Took off cables and cleaned, checked batteries, took off the ground to the cab and cleaned. charging at 14.3 Any ideas what could be the problem or what to check. | |
