North Central Oregon | Current Rate / Gallons Per acre = oz of chemical per Gallon in your tank mix
Desired Rate / oz Per Gallon in tank Mix= Gallons per acre that should be applied.
Example:
4 oz per acre rate in 10 gallons per acre applied: 4 oz / 10 Gal Per Acre = .4 oz per gallon in your tank mix.
If you want to apply 6 oz: 6 oz / .4 oz per gallon in tank mix = 15 GPA applied to get 6 oz rate
edited to improve readability
Edited by Nor-C-Ore-Drylander 7/14/2013 02:23
