Central Sask. RM#254, Canada | Lift one end and put a 4x6 or steel beam across under it sitting on a 45 gallon drum under each end so it is clear of trailer, then go lift other end with loader and drive trailer out from under, then set that end on piece of 2x6 or ?... on ground... Go do same to the end on the barrels... If you have a forklift that will lift it as one piece so you can drive trailer away... Then just lower it ... May have to put a crosspiece on forks to widen spread out ... Chain top beam to mast for safety so cannot slide off forks .. |
