SW Ohio | I kept my 346 as my backup baler. The pickup will leave a strip on each side vs, a 347, same size pickup but less teeth. Most all of the major parts are the same between a 32x , 33x and 34x except the gearbox, The knotter brake is in a different location, and some minor changes in the knotter parts, but basically JD balers have not changed in 30 years. If something works, stick with it. A x4x will be a the larger capacity and might spoil you after running a 311. Almost any baler can be a good one if maintained and operated within its limits, I pushed enough hay through a 273 to feed 2-300 horse lifetimes and it was still cranking them out when it left here. I think my 575 will outlast me now. | |
