Wisconsin | We do some spring plowing and we use a buster bar. Only in the spring though. The reason dad says he wants the buster bar on the plow is to break up some of the lumps and to kind of seal it up. Usually we will disk it shut the next day and then run the field cultivator once before planting. mainly used to seal the ground. we are about an hour north of Madison if it makes any difference | |
