Posted 4/27/2013 08:55 (#3065688 - in reply to #3063935) Subject: RE: ez boom
Tip of the Thumb of Michigan
How's your pump? Does it have enough hydraulic flow or is it spinning, but not pumping enough pressure? Plugged filter in the sprayer lines? Will the rate work at slow ground speeds?
