I use the 750 to output gps to both the 20/20 and a Raven 4xx, or 6xx rate controller. They seem to need different settings (ie. the 20/20 doesn't see the gps signal when the 750 is setup for the raven). Can I save them to config files and then just load the required file, or do I need to change those settings manually?
Thanks
