Posted 4/24/2013 19:39 (#3060610 - in reply to #3060524) Subject: Re: AgLeader Integra Multiple Product Unlock
Missouri
Exactly like FarmWeather said. When you are prompted, be sure to select your current map instance, instead of creating a new map. If you select to use the current map instance, it will map the next hybrid on the same map as the last. If you select new map, you will be starting over.
