Near Intersection of I-35 & I-90 Southern Mn. | Fingers77 - 4/22/2013 20:10
Trying to set up the new to us floater. FIQ controlling the pump through a Raven 460 harness to a DJ servo on the pump hydraulics. I am having a heck of a time getting it to build pressure before I turn the sections on. That and I have a 3" Raven flowmeters that the cal number from the 460 seems to be wrong. Cal number is 410. Any ideas?
Raven flowmeter cals are for 10 Gallons. Many controllers are for 1 Gallon so you might need to use 41 instead of 410.
As I recall the DJ pump servo didn't work very well. Raven makes a replacement for the electronic portion of the hydraulic valve that seems to work much better when a Raven controller is involved. This product is made to replace the DJ electronics but still use the original actual hyd valve.
Edited by tedbear 4/23/2013 07:05
