Posted 4/22/2013 15:10 (#3054970 - in reply to #3054961) Subject: Re: Farmworks to Pro 700 Prescription Planting
roaming
that's the easy part. Insert stick, power up.
Run the Daily Operation Wizard (I assume you're running a 1200 planter), and it will walk you through the steps.
OR, if you don't have the Wizard software installed, or you're not running a 1200 planter:
Go to Work Condition > Layer, and assign your products to the map.
Go to Performance > RxSetup, and assign a prescription to each map layer.
