Butterfield, MN | If it's the data cable, that will not work with a Cruizer I. 115-0171-886 (not 100% sure on that one) is the cable number if I remember right, if you want to double check that. It only works with Cruizer II. Cruizer I will only work with the remote master sense using the 115-0171-792 adapter. You'll have to find the master switch and tie into the master switch wire to make that work. Then go into the tools page and change the "switch" setting from "touchscreen" to "hardware". Then it will turn the painting on and off with the master switch. | |
