Minnesota | Well if you have an FM-1000 it is actually supported through Case IH. http://caseihafs.com/contact.php gives a phone number for their support line. (although I am not sure how long that website will be available before they switch to a new link, phone # should be the same). I am a dealer for both sides trimble/CNH, and your issue sounds like it is something internal in the display itself, trigger for me is the display reverting back to version one. What I would do is let the tractor run with the display powered up (to see if the internal battery will recharge), and then try re-installing the version of display software you were using, or latest version (either way I will guess that your settings are gone without a profile being saved). Area I am in just got an extra 5" of snow so there a little time before we need to be field ready. No loaner display available? | |
