far sNSW , Australia | Driving along road (very quiet dirt one) and the steering went hard on Coupe 3640. Pulled over and no hydraulics either. Fun squeezing out of cab door with boom folded up. Plenty of oil. Cracked the pressure line on pump and no oil coming out with motor going. The pump must be the problem ? It showed no warning signs and stopped working instantly. Today started pulling pump off and one of the 4 bolts was loose, spins and can't be tightened. Some issue from before I got it. Got all the bolts off and the pump itself will not budge. Hit pretty hard and it is tight. What to do now??? ANd what to do about the stripped bolt as it goes into the front housing of the motor. Thanks for any ideas. | |
