Butterfield, MN | I guess before you get that far, it's pretty easy to check and make sure you're getting power to the receiver, assuming it's a 115 or Phoenix 200. If you use a volt meter and check between the 11 and 10 O'Clock pins on the plug going to the receiver you should get 12 volts. If this is happening and it's low, voltage, say below 11ish, or there's none at all, double check your fuse connection and power and ground connections to make sure they're all clean and solid. Varying voltage will really cause issues. With this being an older system, it's a real possibility. | |
