NE SD | Soil conditions have to be ideal, also has to have a good operator. If soil is too wet you get bad results, too dry you get poor results. If there is a lot of residue you get bad results (hair pinning). If the operator drives too fast or too far apart you get poor results. So if your soil is black, and 100 percent ideal soil moisture across every acre and it is pulled around 5 mph. You might get an ok map.
Speaking from experience. | |
