Posted 3/11/2013 09:47 (#2957346 - in reply to #2957314) Subject: Re: Setting ez-steer on CIH 9170???
Great White North
When asked for the Wheelbase put in Axle to Axle measurement....not pivot to axle....on the Angle Per Turn 18-20 should put you in the ballpark. I use axle to axle because that's what it used in the "old days" and those are the numbers I remember. Not sure what the number would be if you use the pivot measurement.
