Hazelton, Kansas | jfqc,
If you are really doing a major on your 1850, go buy both the 3/8 and large 1/2 inch 18v Milwaukees. By "large 1/2 inch", I mean the one rated at 450 ft-lbs (and yes, it really has that amount of grunt). And an extra battery or two.
You'll know why soon after starting that job.
Problem with this plan is that after you use those first two, you will want the 3/8 inch drill, the angle grinder, and maybe the vacuum cleaner, and of course the circular saw, and...
Regards.
MDS
