Unit Serial Number Z9RZ06978 Build Date 11/23/2009 Model MAGNUM 215 TRACTOR CASH CROP HIGH TRAC Engine Serial Number Transmission Serial Number DEG0050165 420012 Deluxe Cab 420014 Performance instrument cluste 420019 Deluxe positive response seat 420021 Foot throttle 420025 Single beacon light 420026 Cab worklights w/ Egress 420050 Standard 86.6 in./2200 mm 420218 Rear axle 4 in. dia. x 120 in 420223 HD MFD frt axle w/Lmt slip di 420302 Hydraulic pump, high capacity 420306 180 Gal./446 L fuel tank 420349 FWF and 10 front weights 420402 Four electric remotes 420519 Cat. III/IIIN, 3-point hitch, 420529 Cat.III High capacity drawba 420701 North American English 420783 Auto Guidance Rdy 12 Bolt Axl 420787 ISO 11783 implement system 420794 19F Speed powershift-Economy 420804 AM/FM stereo radio 420811 Non-spark arresting muffler 420820 Electric adj. ext rearview 420822 Cloth instructional seat 420823 True ground speed sensor 420826 RH Window monitor mounting ba 420829 Low pressure motor return 420874 Engine block heater 420886 Lower fifth flexible cab step 420990 No tire brand preference 429175 540 and 1000 RPM PTO 429307 Display mounting kit 8416444 480/80R50 159A8/B R1W GY 8872444 380/80R38 142A8/B R1W GY
Unit Serial Number Z8RZ05597 Build Date 8/28/2008 Model 69600412 M215 TRACTOR MFD, NAO Engine Serial Number 46931988 Transmission Serial Number 420014000 PERFORMANCE INSTRUMENTATI 420023000 STEP FRONT WINDOW 420025000 BEACON LIGHT LEFT HAND MO 420049000 CAB, NAR LUXURY 420108000 18 SPEED POWERSHIFT 4WD L 420218000 120" BAR (118" ON TC210) 420223000 4WD AXLE HEAVY DUTY W/12 420235000 FRT FENDER NARROW 420268000 SEAT, LEATHER/SEMI ACT SU 420306000 FUEL TANK 605 L (160 GAL) 420349000 SMALL FRT WGT SPRT W/10-4 420362000 FENDER, EXTRA WIDE 2.25M 420364000 CONSTANT GROUND SPEED CON 420400000 MEGA/TWIN FLOW HYDRAULICS 420402000 SPOOL ELECTRO HYDRAULIC 420519000 HPL, FXD BALL 3 PT STD LF 420529000 HEAVY DUTY DRAWBAR 420701000 NORTH AMERICAN ENGLISH 420783000 GUIDANCE READY HD AXLE 420795000 HI CAPACITY ALTERNATOR 420801000 SPACER 5 INCH 420811000 STANDARD MUFFLER 420820000 MIRRORS/ELEC. 420823000 GROUND SPEED RADAR 420825000 MONITOR MOUNT.RH A POST 420826000 MONITOR MOUNT.RH WINDOW 420875000 START AID, BLOCK/TRANS HT 420883000 RADIO BUSINESS BAND 420884000 POWER BEYOND/ HYDRAULIC R 420927000 ALL ROUND LIGHT 420990000 NO BRAND CHOICE 429175000 DUAL SPEED PTO F/EUROPE/N 429307000 COLOUR DISPLAY 429308000 AM/FM RADIO SINGLE CD/WEA 849654400 REAR DUAL 380/90R54 R1W G 887244400 380/80R38 (R1W F/NASO) GO |
