| You have to have the field pulled up for the functional areas to show up. To do that you have to first add a new field through the Setup button and on the left you will have the option for Client, Farm, Field, etc. When you select the option you want, on the right will be a New button and you can fill out that information. Now, when you have that information entered,select add to list and then done at the bottom and then you will go back to maps and pull up that field (Make sure the filter by has "All" for Field, Maps, Crop Season) and it will have you download an aerial image. This will allow you to create a boundary, prescription, etc off of it. If you just want the Field name to unload to card for the display, all you have to do is create it through the setup button and it will be an option for you to save to the card. Hope this helps.
Edited by Tinger 12/3/2012 19:03
