Somerville, Indiana | don't take this to the bank but HyTran is known to have the ability to suspend water, and is right at 20W...Detergent and non-detergent?is that a trick question, non-detergent won't get stains out. Actually
somewhere on the box should be written, caution contents may foam under certain conditions, will probably be
ok in a pressurized tank-this is noticeable running detergent oil in a Behlen hydraulic system, keep the sack on
power steering unit or oil will blow back in your face in road gear...We didn't have good luck with ATF in a backhoe
years ago, but that was at the suggestion of a neighbor who didn't run his very often.
Edited by dave morgan 12/3/2012 09:15
