NSW Australia | Mine has done this several times. After loading v 2 firmware it dose this and also sporadically just turns itself off or reboots for no reason at all it must be glitches in the software I think because everything worked fine before the new firmware. When it gets into the restarting mode over and over I just pulled the power on it for ten minutes and then try again until it come good. I will stick with the new firmware upsides are greater than the downsides. | |
