Search Forums | Classifieds (227) | Skins | Language
Case 4490 final ratio?
Old Pokey
Posted 12/1/2012 10:19 (#2726626 - in reply to #2726483)
Subject: RE: Case 4490 final ratio?
twraska - 12/1/2012 06:02
Old Pokey - 12/1/2012 07:49 What I have to remember is that because I am only turning one planetary and the other is grounded, the pinion yoke count is doubled.
If I am understanding this statement correctly, you're thinking backwards. By turning only one wheel the pinion count will be half, OR,,,,,, you have to turn one wheel two turns. i.e. If the tractor got stuck and only one wheel was spinning it would be spinning twice as fast as normal speed.
 Crap!!!  I think you are right. Dang dixlesica. Thanks for correcting that error.
