Posted 12/2/2012 07:35 (#2728107 - in reply to #2725937) Subject: Re: Fertilizer coulter shimmy
The speed you are running plus the fact that there may be some wear in you coulter pivots are the factors which are probably causing the whipping. We can bore out the piovot castings and install hardened steel bushings. 740-756-4810 www.hizeyfarmservicellc.com
