Posted 11/22/2012 22:31 (#2711711 - in reply to #2711651) Subject: Re: Even using a feed wagon...you waste hay (pics)
south central IOWA
I made it. 1" strap with Lexan pop riveted to it. 2 simple hinges that I can pull a couple pieces of No. 9 wire and the door is off. The latch is just a simple latch too but hard to explain. Then there is 2 galvanized pieces of angle iron bolted to the skid loader down where the door is narrow. I can get some pictures if you looking for ideas to make one.
