Posted 11/22/2012 05:53 (#2710288 - in reply to #2710157) Subject: Re: JD 9600 Update - Major Problems
ecmn
overhauled a few of them trannys, nothing to hard about them. we used roller floor jack, took the pad off and made a plate about a foot wide and couple feet long of 1/4" flat, lift it up to the tranny, ratchet strap or small chain binder to the plate. unbolt it from the combine and lower it down and roll it out.
get a tech manual for the combine and it will give you any specs you need for the tranny.
