Search Forums | Classifieds (202) | Skins | Language
Replace early riser montior with pro700
Bleed CIH Red
Posted 11/21/2012 14:52 (#2709452 - in reply to #2709309)
Subject: Re: Replace early riser montior with pro700
SW part of the "Cyclone" State!!
Does it have Dickey John high rate sensors on it? You could put Accu-Control on it by using Trimble section control module and a seed monitoring module and unlock the 700 for Accu Control and then you should be able to do that. Torn, correct me if I'm wrong?
