Central Missouri | Bioforge was the best in the plot. You should have cut a longer swath. Your data could be somewhat scewd with having so little weight; so I would repeat the plot next year before I was convinced of anything for sure. A good start on collecting data though. I like smaller plots like you did, but with that little of weight errors get magnified greatly (like not cleaning out the combine well each time, or a huge machine for a little bit of grain). Also this was a drought year so you may have differen results next year. | |
