Minnesota | Those sensors should work fine. What you will need is a Field IQ Cab Kit PN ZTN80810-02, Implement Kit (Varies by rows and Models) and a Seed Monitoring Module Kit (for 24 rows or less you will either get PN# ZTN80510-50 if you were previously using a DickeyJohn style Planter monitor or ZTN80510-55 if you were using a CompuTrak CT John Deere Style Monitor). If you don't have a monitor with the planter you can easily tell which style it is by the pinout of the 37 pin connector on the DickeyJohn Harness on the planter. | |
