NE ND | 440 zl 97' artic cat. Ran fine when it was parked last year. Stared this year and one cylinder is flooding with fuel. Plug is all wet when pulled out. It will run with throttle half open or more. Pulled bowl off. Float, needle and all are clean and good there. Choke seat had a few burs on sides so I switched the choke cables with other carb. Thought if that was problem, the other carb would experience the problem. It did not. Same cylinder is flooding. What next? TIA | |
