Interstate 35 North ia | I had to put the front timing cover on a 2388 that had a fire , the gasket that sits behind the timing cover has had a update or 2 and the tin cover that sits on the front of the timing cover is also been updated . So make sure the oil is coming from the front seal first . The seal itself is real easy if you have the room to remove your vibration dampner , the seal housing bolt to the timing cover . good luck The tin timing cover is known to crack from vibration the updated tin cover is stamped out a little different to solve the cracking problem . | |
