Posted 11/8/2012 22:49 (#2686860 - in reply to #2686707) Subject: RE: NH3 cooler and rate control that runs thru a pro 600???
East Central Ia
You can connect the Pro 600 to a Raven through the serial port for logging... but it will not rate control and you will still have to have a second controller in the cab. We have done this with a Raven 440 controling the NH3 and had it connected to the Pro600 via serial port so the Pro600 could map out what we did.
Its unbelievable that Case IH hasn't come up with a way for the Pro600 to do this!
