Posted 11/8/2012 18:07 (#2686206 - in reply to #2686098) Subject: Re: Whats it worth? Insight with Direct Command
East Central Ia
Not without the Autopilot unlock. With the Autopilot unlock then yes it will steer that setup as long as you have the Trimble software on the Nav2. If is the Case IH version of the nav2 then you can send it in and have it reflashed to trimble software... at least you could. Not sure if you still can or not... and I have not had to do it.
