roaming | If you're already doing yield/moisture monitoring, and you just want to add yield/moisture mapping, you just need to add a receiver, and just about any receiver will do. If you want guidance, you need to have the Autoguidance software installed in the display, plus you need some additional hardware on the machine (i.e. guidance valve, steering sensor, manual override sensor, NavII controller, etc.) if not already installed, plus you need one of several specific receiver models (162 with unlock, or 252, 262, or 372). | |
