Near Intersection of I-35 & I-90 Southern Mn. | I'm familiar with what you did in replacing the D.J. with a Raven. As far as switching back, I'm afraid you will have to go back to the D.J. coffee can style. The Raven D.J. replacement used the same style connector as the original D.J. so as to make the swap easier. This was a 4 pole AMP connector that used three wires. There is a pair for Inc/Dec and the third wire can be used for a Valve Max indicator light. |
