Clatonia, NE | If you have rolling terrain, the GeoSteer GCU is much better than the ECU4... it better be for the price! I still have a Ontrac 2 that I was moving around 2 tractors. I decided to leave that one in the sprayer tractor (doesn't need to be as accurate) and put the GeoSteer in my planter tractor (that does other things also). I'm still moving my MDU back and forth. The Ontrac 2 and plus are both great systems in flat ground. They both fall down a little in terraced ground when rolling over the terraces. The MDU is a great mechanism to steer with... great if you want to move the system around! | |
