Posted 10/25/2012 09:26 (#2659962 - in reply to #2658263) Subject: Re: Educate me about pulling pipe or I-beam to level ground
Wardview, LA
One trick on rough hay fields is to pull two I-beams in tandem when the grass is half a boot high with the ground dry and anthills close to dry, it will smooth the fields so that they are a lot more tolerable when cutting hay and flat smooth out some anthills.
