Spring Grove MN | For 2012 the height sensors are moved to the end snoots. They will now allow you to use the HHS and drag the tips on the ground for down corn. My understanding was you could not get closer than an 1" or 2 from the dirt with prior models. The snapping rolls and shafts are changed. They are not supposed to come loose with this "new" old design. They changed the shaft taper to be longer for more contact area - more similat to the 90 series. They added gas assist struts to the points, so folding them completely up and out of the way is easier and they can no longer bust the glass out of your cab if you happen to let go of them when flipping the up. | |
